Its model # E15R4SSE MAN DATE OF 12/99. what year would tha make this motor?
I bought it from a marina said it had little use to no use as an old man had bought it and died before ever using it.
It ran ok, always seemed lacking a little umph. After starting and running to a spot it always gave me a headache to restart, so I figured carb and rebuilt it. I took it all apart and it was CLEAN. Motor looks like its brand new.
I took it out this past Monday and got stranded and had to paddle in some 6 miles against the current, breaking an oar half way in I ran ok out to the first spot and did the same old thing again. However after I got it started it ran and we were headed to another spot when all the sudden it started bucking and spitting then I heard the noise.
I took the cowl off and water was spitting from the carb when I tried to restart it. It is a pullstart, and there was no compression on it at all. I checked oil and it was full of water, so I figured blown head gasket, head cracked or possibly block. I got it home took the lower cover off and got the valve cover off and found a broken spring on the top cylinder #1 spring. I am not sure of firing order so this would be the top spring as looking at it. The retainer is also chewed up.
I am fixing to tear further into it to see what else is wrong. I bought this motor because I am disabled and I was tired of having to work on old stuff everytime I went out. This seems catastrophic so early into it. I have found exploded diagrams to aide me in repair and I am very well adept to car motors. From what I have found so far I have to buy a whole assembly, I can't just but new springs and retainers etc as I need them. Is there anywhere to get these seperately?
Also in a car motor I would replace all bearings at this point. I am seeing that these are actual bearings is it necessary to replace them at this point? I am ordeing a repair manual for guidance, if there are any online that you guys know of that I could use or any other pertinent info you can give me I sure would appreciate it. I just watched 3k go up in smoke literally with only 4 uses on it. I am on a fixed income and well this really hurts to say the least. I will take ANY advice on this motor I can get with gratitude. For example, anything that can or should be upgraded while I have it all apart. Thanks in advance for the replies.
