Re: will elec ign. conversion effect timing?
Yep you should set your timing just as with points. Just for curiousity, check how much dwell you have with the electronic ignition. I was having running problems with my Pertronix unit and I think it was due to insufficient dwell. I increased the air gap and now have 56 degrees dwell. Will see how it runs now.
Have a great day
Rob.
