Greetings,
I have a 1996 Force 120 that will not tilt/trim up. It will operate in the down direction though. I have the square motor 3-wire system which is now discontinued.
It worked fine before winter storage but has not worked in the up direction this year. I have confirmed that the motor spins in both directions. With the motor and valve body disconnectect from the ram, I get oil flow when I operate the motor in the down direction. The oil flows out of the port opposite the limit valve. I am assuming the middle port is for the up dirction, but when I operate the system up, I get no oil flow. Is the middle port for the up oil?
I can move the ram up and down with the valve body and motor disconnected. Since I can move the ram and I get no flow in the up direction I think the problem is somewhere in the valve body. Does that sound right?
Thanks in advance for any help.
