  #1
Old July 10th, 2009, 04:01 PM
kevster66 kevster66 is offline
Talking What battery do I use ?
I have a 2008 16 foot lowe stinger.
I am putting a stereo with 2 speakers in . Right now I have 2 batteries.
The cranking battery runs all accesories.( One fishfinder /GPS, another fishfinder up front,lights (dont use really),live well ,bilge )
The other just runs the trolling motor.
Should the stereo be hooked up with the other accesories on the cranking battery?
The trolling motor battery should be kept seperate I am told.
Any suggestions would be appreciated.
Kev
  #2
Old July 10th, 2009, 06:17 PM
DeepV DeepV is offline
Default Re: What battery do I use ?
I would keep the stereo off the trolling motor battery too.
It takes quite a while to drain a battery with a normal stereo system. I made a small pair of jumper cables from some heavy wire I had laying around. If I ever do drain the cranking battery, I can still jump it to one of my 2 trolling motor batteries.
__________________
2008 Lowe FS 175 with 115 Optimax
  #3
Old July 10th, 2009, 10:26 PM
bryonthefly's Avatar
bryonthefly bryonthefly is offline
That 60 amp alternator on the optimax keeps the cranking battery in tip-top shape also.
__________________
Lowe FM165
75 Optimax
  #4
Old July 11th, 2009, 06:34 PM
Great point!
I rarely charge my cranking battery at home but sometimes I have the boat stereo going when I'm messing with the boat in the garage and I have run it down after about of week.
__________________
  #5
Old July 13th, 2009, 09:54 AM
I only have one trolling motor battery.
So you are saying I can start the motor if i kill the cranking battery by jumping that battery to my trolling motor?
I have an onboard 5 amp charger which charges both batteries at the same time . I just plug it in when i get home.
I only have a 50 mercury on the back.
Does it have an alternator in it?
I am not too familiar with boat motors. This is my first boat.
Any info would help and thanks to you all for your input thus far!
  #6
Old July 13th, 2009, 11:10 AM
rouge1's Avatar
rouge1 rouge1 is offline
Yes it should have an alternator but I think that only charges the starting battery, not the deepcycle trolling battery, also you should check the water level of your batteries once a month if you are plugging in the onboard charger when you are not using the boat. Batteries are not big fans of heat, charging and discharging generate quite a bit of heat also with summertime ambient temps your batteries will tend to use a bit more water. With the charger unplugged and the batteries cool, pop the caps and make sure that water (acid) level is visibly above the plates in the battery yet about an inch below where the caps go in the battery, also clean of any corrosion that builds up around the terminals. If your batteries need water added to them use distilled water not tap water, to many unknowns floating around in tap water.
  #7
Old July 13th, 2009, 11:10 PM
Thanks . I allways check on batteries. An yes distilled water only!!
I have decided to go with cranking battery. I am going to leave the trolling battery alone.
I am getting the stereo put in tommorrow professionally just because it is a new boat and I will have to have around a dozen beers to cut a hole in the deck of my boat for the speakers!!!LOL
And I also don't want to watch!!LOL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How do I properly wire dual battery charger to starting battery? strokeoluck Electrics, Electronics and Trolling Motors 3 May 17th, 2009 02:17 PM
Deep Cycle Battery Freshness - 14 month old battery for sale at Walmart RonBurgandy Electrics, Electronics and Trolling Motors 3 May 10th, 2009 09:15 PM
Battery switches question / Charging both battery 1 and 2 at same time MyStriper21 Electrics, Electronics and Trolling Motors 3 August 13th, 2008 11:55 AM
Charging starter battery and trolling motor battery arniep Electrics, Electronics and Trolling Motors 8 March 26th, 2008 01:26 PM
Battery charging and testing - desuphation - Battery MINDer strippingguards Non-Repair Outboard Discussions 4 May 18th, 2003 02:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
