  #1
Old July 10th, 2009, 12:10 PM
duscarter duscarter is offline
Default Ill fitting tower
My buddy bought a used steel tower for his boat. It almost fits perfect. The angle is a little off where the tower bolts to the boat. We tightned it down as tight as we could, and still have about a half inch gap at the bottom of the plate. The top part bolted up tight. The rack is on snug now.
It's because the angle is off.
Should we just try to fill the gap with something that would make it look cosmeticly correct?
Since it is steel, can a welder heat the medal to get it to go down flush?
Any other ideas?
  #2
Old July 10th, 2009, 12:33 PM
Hogger's Avatar
Hogger Hogger is offline
Default Re: Ill fitting tower
I sure wouldn't be tightening it as much as you could if it doesn't fit. Now you have a lot of additional stress on the hull, and may weaken the area around the mounting holes. Since the holes are usually close together, that whole mount area may be fatigued and could fail.
I would take the tower off, and take a lot of measurement to be sure the tower is square. If it truly is square than you probably have a bad foot.
Do not try to heat the tower to bend the foot to the right spot. That will change the properties of the steel and could make it weak and or brittle.
I think the best would be to cut the foot, or both feet off, then re-measure the angle where the new one needs to go. And weld them on.
  #3
Hansolo99 Hansolo99 is offline
A pic would help, but I will try and answer. I am not sure about a welder being able to bend the end. It would be bad to weaken that area with heat and comprimise the stregnth that is needed when pulling someone. I would suggest maybe a machined peice of aluminum (like a wedge that would fit nicely) or a solid peice of ABS. Whatever you decide make sure the the bolts and backing on the inside are FLAT and secure. I got a solid piece or wood (the good stuff not press wood) put gorilla glue between the HULL and the WOOD and tighted everything down secure. It held up like a champ with NO loose fit and made for a beefed up mounting area I was satisfied with. Just my thoughts hope it helps.
  #4
Old July 10th, 2009, 01:18 PM
lowkee's Avatar
lowkee lowkee is offline
Call me crazy, but why not just bend it to fit? Assuming you can't get it to bend using whatever means, making a shim will allow you to add surface area, which is needed to spread the stresses out. Be sure you have a fairly big backer board on the other side which conforms well, as those towers put a lot of stress in a small area. You don't want to be asking how to fix a hole on your boat tomorrow.
__________________
1990 Bayliner Capri 2050 BR - (My first runabout; Never seen her in water) ***Restore on hold until Jan 2010***
Restoration status: 0% --1--2--3--4@--5--6--7--8--9--10 100% Watch my progress here
1-Teardown 2-Transom 3-Stringers 4-Deck 5-Paint 6-Repower 7-Interior Frames 8-Seating 9-Water Trial 10-Upholstery
The 10 steps of restoration denial - Which step are you?
  #5
Old July 10th, 2009, 03:05 PM
Here is a pic of the worst one. We were thinking of trying to bend it too. We are going to add a board backer in addition to the metal backer it already has.
It would be really tough to get the angle on a shim. Let me know what you guys think.
  #6
Old July 10th, 2009, 03:32 PM
lowkee's Avatar
Honestly, that tower leg looks as though someone made it out of exhaust pipe and put some clear coat on it. Heck, the weld isn't even flush, so time wasn't even taken to make it look pretty.
If you can weld (or know someone who can), I would just cut that and re-weld it.
__________________
  #7
Old July 10th, 2009, 04:00 PM
That is bad! I agree cut and weld a whole new piece (a nice strong weld for sure).
  #8
Old July 10th, 2009, 04:53 PM
Hogger's Avatar
The hull looks contoured, so make sure that your new foot matches the contour of the hull. Your backer plate also needs to be contoured, don't use a flat piece, you won't have proper distribution of weight/forces.
  #9
Old July 10th, 2009, 06:01 PM
Utahboatnut Utahboatnut is offline
Looks like right where the weld is it is kinked some if it were straight it might be a pretty good fit. I would cut and re weld as stated might even use a collar on the inside of the pipe to add some strength. A good nylon or hard rubber pad under the foot and reinforcement plates on the inside of the hull.
  #10
Old July 10th, 2009, 09:32 PM
superpop's Avatar
superpop superpop is offline
Unless you do not care about gel coat cracking around the mounts, I would get that tower off and get the right mounting feet for the contour of the boat. Remember, you are dealing with a very brittle structure, it is very strong but the pressure from the mounts needs to follow the contours of the boat, and no, rubber or wooden bushings are not going to fix the problem. You will develop cracks and crazing around the mounts unless it is done right. If you are going to use steel or wooden plates on the backside I would also recommend bedding them in with some fiberglass so they sit flat. If you go to www.samsonsports.com they have a great video that explains the installation process and why it is important. If it is an old beater boat then it may not matter as much, cant really tell from the pics.
__________________
There is no replacement for displacement
2006 Chaparral 204SSi
VP 5.0L GXi-F with SX Drive
  #11
Old July 11th, 2009, 12:30 AM
redone4x4's Avatar
redone4x4 redone4x4 is offline
Send a message via Yahoo to redone4x4
Quote:
this is what i noticed...looks like it was originally designed to match the hull more, but the weld wasnt square. what does the rest of the tower look like? any more shortcutting on the fabrication that should be reconsidered?
__________________
Samuel Adams. Always A Good Decision.
1987 5.0 OMC capri 1950CX bowrider, 3 bow 6 ft. Westland bimini
  #12
Old July 12th, 2009, 11:55 AM
He sold that tower and ordered an adjustable one. Neither of us can weld, and the expense of getting someone to would have been too much. Thanks for everyone's feedback.
I will post pics of the new tower once it is installed.
  #13
Old July 21st, 2009, 10:28 AM
Here is the new tower. It fits much better We reinforced the mounting points with wood too. Just ran the speaker wire last night.
  #14
Old July 21st, 2009, 10:31 AM
lowkee's Avatar
Very nice looking tower! That is exactly the one I'd like to get for mine. Simple yet flowing design.. perfect!
__________________
  #15
Old July 21st, 2009, 12:44 PM
They are very reasonable. Just Google Avenger wakeboard towers. $699 with free shipping right now. The aluminum is high quality too. It takes a lot to drill though it. I enjoy follwing the progress on your boat.
We just ripped out all the carpet this morning. Going to sand it, and put down a non-skid paint. We had to Marine Tex a couple of holes we made for the other tower. If you have to break out the paint, mind as well do it all.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Anyone have a big air h20 tower? or........... JB25VIP Wakeboarding 3 April 2nd, 2009 11:27 PM
76 150 tower Searay 150merc Mercury & Mariner Outboards 4 September 16th, 2008 06:21 PM
My 100% DIY Tower Liquid_force Wakeboarding 4 September 2nd, 2008 02:49 PM
is a tower a must? petrey10 Wakeboarding 6 May 29th, 2008 03:59 PM
Tower DAG Boat Topics and Questions (not engine topics) 7 February 13th, 2005 09:44 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
