Re: 80 HP Mercury reverse lock setting
With the lower unit shifted to FWD and Just getting ready to shift to Neutral, the reverse lockout rod in the center section should point to the middle of the ramp in the shift cam.
Such that, as soon as you shift into Neutral, the very top of the shift cam blocks the reverse lockout rod from springing down. Which keeps the lockout hooks wrapped around the tilt pin in both Neutral and Reverse.
HTH...........ed
