  #1
Old July 10th, 2009, 04:45 AM
adobo adobo is offline
Default new boat owner outboard question
i have a twin e48eslce outboard, wanting to know if they have built in alternators or something to charge my 12v marine batteries. Got electronics hooked up to it, and dont know if batteries are being drained by the electronics. (vhf,cb,cd deck,two lights) Dont wanna get stranded out at see or cant start it at the dock. Thanks
  #2
Old July 10th, 2009, 05:05 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: new boat owner outboard question
threy have a stator and rectifier, as a charging system to maintain the starting batteries. but the diagram does not state the amperage of the stator. it may just be enough to maintain the batteries for starting.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 10th, 2009, 05:47 AM
5150abf's Avatar
5150abf 5150abf is offline
As TD said, yes and no, tey will put out a charge but the motor has to be running at a moderate to high RPM for it to be much power adn it may/may not work.
Stators fail, rectifiers fail, you need to check voltage with the engine off then again with it started and see if the voltage goes up when running, DO NOT dissconnect the battery cable when the engine is running, check with the cables hooked to the battery.
I charge both my batteries every time before I go out, can't go wrong there.
__________________
GO IRISH!!!!
  #4
Old July 10th, 2009, 06:02 AM
Vic.S's Avatar
Vic.S Vic.S is offline
They are only the round non regulated type of rectifier so they are only going to be lowish output stators (6 amps ?) or the batteries will be overcharged.
VHF will take several amps when transmitting, CB also but not so much as a VHF on full power.
CD could take quite a bit if you have a massive audio output.
Navigation lights and deck lights you should know the power of but LED based lights in their place would be more frugal.
In addition to not disconnecting the battery while the engine is running take great care not to connect the batteries with the polarity reversed. Instant death to your rectifiers if you do!
__________________
If it aint broke dont fix it!
If all else fails read the manual
  #5
Old July 11th, 2009, 08:35 AM
thanks guys for the info
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Possible first time boat owner question? btowndms Boat Topics and Questions (not engine topics) 8 June 4th, 2008 08:08 AM
***Prop Question?**(new boat owner) Campnc Prop Questions and Topics 4 July 1st, 2007 09:44 PM
Prop Question(New boat owner) Campnc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 30th, 2007 07:34 PM
Old Boat... New Owner... VRO Question brettagostini Johnson & Evinrude Outboards 6 July 15th, 2003 12:22 PM
New Boat Owner-simple Gas question darkalley Force & Chrysler Outboards 2 May 22nd, 2002 11:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
