Ok i installed a new (used) throttle box on my 1975 Johnson with the red plug got everything hooked back up but now the fuel guage doesn't work got the wire coming off the (I) termenal that was in the other box but not sure what wire it was connected to. Thought it should be hooked up to purple wire coming out of throttle box but when i hook it up there the guage still want move with switch on. The switch was working when i removed the old box so now im completely lost hooked it up the same way i did tack, tack works when switch is on but fuel doesn't
