  #1
Old July 9th, 2009, 05:45 PM
Bob1944 Bob1944 is offline
Send a message via Yahoo to Bob1944
Default 1963 Evinrude 40 HP Electric Shift water and oil mixing
I have changed the seals but still get a milky mix. Am I expecting too much? I think the oil should be nice and oily after running and shifting. What do you think?
  #2
Old July 9th, 2009, 06:12 PM
R.Johnson R.Johnson is offline
Default Re: 1963 Evinrude 40 HP Electric Shift water and oil mixing
That gearcase hase two stud's that hold the upper, and lower together. Under those stud's is a metal seal, like a spark plug seal, or washer. You can have a leak there. What you need is a gearcase pressure pump, and the ideal thing would be a pressure, and vacuam pump. If you were to pressurize that gear case, and put it in a tub of water, you would find your leak. That case has several source's of leak's. You could spend a lot of time, and money without the proper tool's. By the way, every one want's to do this pressure,or vacuam test with the gearcase at rest. Turn the drive shaft while under pressure, or vacuam, and see what you have. Does your Seloc manual mention those metal seal's under the mounting stud's? I would guess not.
  #3
Old July 9th, 2009, 08:09 PM
F_R F_R is offline
Quote:
I was about to consider that a nutty reply, till I realized what stud seals you were talking about. Yes there are two of them (307086) where they screw into the lower gearcase. But it is highly unlikely that they are leaking unless somebody has been messing with it. They are to be torqued to specifications. What does happen sometimes is one of the studs breaks, allowing the upper and lower gearcase to separate a bit and leak. If the second one breaks, the problem is resolved because the lower part goes to Davey Jones' locker. They break for two main reasons: Improper torque or bent upper gearcase. A close look at the upper gearcase reveals how skinny it is and you can see how it is easy to bend.
  #4
Old July 9th, 2009, 08:36 PM
They will also leak when the stud starts to turn before the retaining nut after some corrosion.
  #5
Old July 9th, 2009, 08:40 PM
FR: How much can that upper gearcase be bent?
  #6
Old July 9th, 2009, 11:05 PM
this is a sweet little engine, it runs like a champ but what I'm reading here makes me wonder if it is worth taking that bottom end apart to see where it is leaking. I am beginning to think those two studs could break when I take it apart. That upper and lower seem to be solid in their connection. Any advice?
  #7
Old July 10th, 2009, 12:34 AM
That gearcase has a square section spring, and hub on both on both gear's. It will not tolerate much water contamination. Once that spring slip's on the hub, It is pretty much done for.
  #8
Old July 10th, 2009, 09:52 AM
F_R F_R is offline
Anything up to severe. Ever see a guy launch a boat on a too-shallow ramp without tilting the engine and the whole boat is practically standing on the lower unit? Or a boat moored or beached with the lower unit stuck in the ground and wave action ramming it back and forth? It only takes a few thous to break studs or drive shaft.
The only way to know if it is bent is to take it apart and check it on a surface plate with a dial indicator, as described in the service manual. But unless the studs or drive shaft are broken, not much need to suspect it, huh?
bob1944, don't assume it needs to come apart at the studs. As already said, pressure test it to see where it is leaking. Besides, many a coil wire has been broken by taking it aprart at the studs and letting the lower half drop. Know what you are getting into.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1963 Evinrude 40 HP Electric Shift water and oil mixing Bob1944 Johnson & Evinrude Outboards 1 June 13th, 2009 10:17 AM
1963 Evinrude 40 HP Electric Shift water pumping problem Bob1944 Johnson & Evinrude Outboards 2 June 13th, 2009 09:47 AM
1963 Evinrude 40 HP Electric Shift Bob1944 Johnson & Evinrude Outboards 3 May 4th, 2009 09:38 AM
1963 evinrude 75 horse electric shift Jeffrey M Goldberg Johnson & Evinrude Outboards 3 September 4th, 2003 03:20 PM
1963 Evinrude fat fifty electric shift? jwestfall Johnson & Evinrude Outboards 1 July 19th, 2002 02:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
