Re: Strange cooling problem Yamaha 5 hp 2stroke
Hi Robert
Thank you for the reply.
I was thinking, is it not so that above the piston (combustion area) in a two stroke engine, therre is always some pressure ( explosion, exhaust gasses, compressing fuelmixture)? Under the piston there is at one stage a vacuum.
Now, how could the waterpump make so much pressure to enter the combustionarea and spoil the runningprocess of the engine.
Whereas it would be easy if the (cooling)water enters somewhere under the piston during the suctionphase of the piston and then press it together with the fuelmixture through the sidevent (dont know the english word) to the combustionarea above the piston.
Is that more likely?
regards
Juup
