I have a 1995 Rinker 265 with a Mercruiser 5.7L and Bravo 2 outdrive. At the end of last year it had been running poorly (backfires & hard to start), we had it looked at and they replaced the alternator, spark plugs, cap and rotor, coil, and the fuel filter. Since then we have devolved some additional problems.
It will start and run excellent for a long while. 30 min or more depending, but at some point it will loose power and the RPMs will surge. Going from 3500 to 3000 to 3800 or more and will continue to do that until the engine cools down. I can run at lower RPMs (3000 or less) with no problem, but it will surge or not run any higher then that till it cools.
One odd part is it seems that using any high draw electric such as the trim tabs, or motor trim will set the surging problem off. But not until the engine is warmed up. For example if I try and trim the motor up, the RPMs will drop by 500 or more, and the engine will start to surge.
My guess is there is more then one thing going on here, but I am clueless as to where to start. Our lake has terrible service and it is no easy task to take the boat out of the water and bring it somewhere. Any ideas and help would be greatly appreciated.
Thanks in advance!
Adam
Thanks in advance!
Adam
