randy 1669
- Jun 15, 2009
- 3
I have a 1986 johnson gt200(j200stlcdr) that will idle and run fine on a flushing attachment, but will only tach 2200 - 2500 rpm in the water. I have rebuilt the carbs, replaced the VRO pump, BOTH power packs (had one not firing the coils), new plugs and fuel line. Good compression with only 4 lbs difference between all 6 cylinders. Fuel is fresh with marine formula Sta-Bil. In the water in gear it will only hit a max of 2500rpm. If i kill the motor and restart it, it smokes and smells like it is loading up on fuel. Could this be the timer base not advancing the timing properly? Any ideas?
