  #1
Old July 8th, 2009, 08:39 PM
ambien ambien is offline
Default 1977 Evinrude 35hp plastic flywheel piece?
I have a 1977 35hp Evinrude that has, all of the sudden, refused to start.
I can't even get a cough out of the thing, and after taking the cover off I noticed a sheared off plastic piece that inserts into the flywheel assembly.
Basically, there is a small plastic piece that inserts into the flywheel assembly, and as the flywheel turns small metal flanges hit this plastic piece causing it to rock back and forth slightly. This is the best description I can give. I can't find it on any parts diagrams either.
Can anyone tell me, based on my pretty weak description, what this piece is? I'm thinking it's part of the neutral safety switch. However, I can still pull the cord, so maybe not?
  #2
Old July 8th, 2009, 09:14 PM
Whoopbass Whoopbass is offline
Default Re: 1977 Evinrude 35hp plastic flywheel piece?
Sounds like the neutral safety switch to me as long as your outboard is started with a rope. The plastic neutral safety switch is usually white in color and there is two plastic parts that make it engage or disengage.
As long as you can pull the rope it should fire so it sounds like you have something else wrong with your motor. Might want to check and see if you have spark and then go from there.
  #3
Old July 8th, 2009, 11:25 PM
tx1961whaler tx1961whaler is offline
That part sounds like it is the nylon pawl for the manual starter.
  #4
Old July 9th, 2009, 05:41 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
neutral safety switch is on the shift side of the motor. sounds like a pawl. #11 in diagram. http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old July 9th, 2009, 07:26 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Did the 35 have a starter lock-out to prevent the pull-starter from being pulled in gear? I know my 22-cubers did, can't remember if the 31s did... I suspect Ambien is confusing his recoil with his flywheel...
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #6
Old July 10th, 2009, 03:35 PM
Okay. Yes I am confusing the flywheel with the recoil. But since I can still pull it, I'm assuming this is not the problem, and I should look elsewhere. This shouldn't effect ignition in any way, right?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 35hp Evinrude j-flat Johnson & Evinrude Outboards 0 March 27th, 2008 05:40 PM
Does Johnson '83 48hp have peer hole plastic piece? ba_50 Johnson & Evinrude Outboards 8 December 21st, 2006 07:56 PM
1977 35hp Evinrude BoatBuoy Johnson & Evinrude Outboards 0 September 27th, 2005 01:41 PM
Found a piece of hard plastic in the peehole.... willtill Johnson & Evinrude Outboards 0 June 7th, 2003 05:26 AM
White Plastic Piece in Fuel System? Brew Johnson & Evinrude Outboards 3 September 16th, 2002 12:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
