I'm a brand new member and this is my first posting. I'm working on a multi-family owned pontoon with a 1997 35 hp 3 cylinder Evinrude.
The original report was the engine was missing out badly. I knew we were running a tank of gas that included some left over from last season so I put some fresh 93 octane in a 6 gal tank and plugged that in. I also replaced the plugs with the proper gap and replaced the fuel filter. The boat started every time and idled smoothly under no load, it seemed smooth up to what the tach said was 4000 rpm. I ran it 35 or 40 min on the lake. It ran smoothly until the tach said it was over 4000 rpm then it over reved, the tach showing over 6000 rpm without changing the throttle. It would run very fast for a couple of seconds then slow down and in most cases die. Then it would restart and I could run it at 1000, 2000, 3000 & 4000 without problems then it would go nuts as I approached 5000 rpm.
I then pulled the plugs again to see how they looked. They were fine but then it refused to start. I pulled #1 and it had no spark. I pulled #2 to check for spark and the thing started and ran too well to be running on a single cylinder. I could try the starter several times and have no start at all and a few seconds later it would fire up and run smoothly as soon as I hit the starter.
I'm thinking I have at least 2 problems but thought I'd throw this out to you guys to see what suggestions you might have.
Thanks
PS I tried to post this an hour or so ago but I never saw it come up so this might show up as a repeat.
Thanks
