  #1
Old July 8th, 2009, 02:19 PM
JBeach327 JBeach327 is offline
Default 02 192 Captiva With list to left
Anyone else have this problem? Anyone try trim tabs? Have talked with one other person so far same year boat different engine same problem.
  #2
Old July 9th, 2009, 09:35 AM
mvn's Avatar
mvn mvn is offline
Default Re: 02 192 Captiva With list to left
How does it sit in the water when you're stationary? Does the problem crop up when you are underway? How's your weight distribution?
Mark
__________________
2005 Rinker 192, 4.3L Volvo SX, SX Smart Tabs, Precision Props 4-blade SS prop
2007 GMC 2500HD Duramax/Allison @450 hp haulin' it all
  #3
Old July 9th, 2009, 03:05 PM
Sits level in the water, weight distribution fine, does it with 18 pitch 4 blade alu, 21 pitch stainless 3 blade, 21 pitch alum 3 blade. Trim set down, trim set mid way. Has the 5.0 carb. Another person I talked to the other day same boat W/ 4.3 does the same thing. If I install trim tabs will this help? Will tabs mess with top speed on boat.
  #4
Old July 10th, 2009, 09:33 AM
mvn's Avatar
mvn mvn is offline
I haven't come across this issue on mine.....strange. Properly tuned SmartTabs will not harm your top end. In fact, it may increase it slightly. Will it cure your issue? Maybe. You may want to pose your question in the general forum here or talk to John at Nauticus (SmartTabs). You can also ask the question over at rinkerboatowners.com if it's a model specific issue.
Mark
__________________
  #5
Old July 15th, 2009, 10:36 AM
Ok Spoke with the people at Nauticus about the smart tabs. They assure me that the SX Smart Tabs will correct the lean problem. I am getting some with the PR500 set up so I can raise them when mooring off shore. Figure I will need them for the fact I normally have to trim up to trailer height so not to stick out drive in the mud. After I try the I will let you know how they did.
  #6
Old July 24th, 2009, 11:07 PM
mvn's Avatar
mvn mvn is offline
I found that adding the tabs corrected all of the problems I was having but another cropped up. You may find in tight turns that you will get significant ventilation, or blow out, of the prop, that is, if you are using the stock aluminum ones. I found that going to a cupped stainless, I my case a 4-blade 20" Turbo fixed that issue. You may find that your 21" 3-blade stainless will perform the best.
__________________
  #7
Old July 28th, 2009, 09:44 AM
Smile Re: 02 192 Captiva With list to left
Tabs went in great, got control on choppy water, plained better. Low speed still has slight list to the left. 5 people on board. Need to adjust tension and retest. WOT down alot and top speed down. Did not give enough time to see total top speed. More concerned with list. Will let you know how they do after adjustment.
  #8
Old July 29th, 2009, 01:07 AM
td192 td192 is offline
Please post pics. of installed trim tabs. I want to put them on my 192 and would like to hear how they work out. What model did you purchase?
  #9
Old August 6th, 2009, 02:31 PM
dorf_online dorf_online is offline
I have heard in other forums that the choice is the 60lbs smart tabs SX. Which did you use and where the heck did you mount them?
__________________
Jerry
"dorf_online"
rundorff@hotmail.com
  #10
Old August 7th, 2009, 08:48 AM
mvn's Avatar
mvn mvn is offline
Right here Jerry....
__________________
  #11
Old August 10th, 2009, 03:05 PM
Spoke with Greg at Nauticus regarding the trim tabs. He suggests going with the ST1290-60. He didn't recommend the Smart Tabs SX because of our hull design. He shared with me a recommend install photo of the ST1290-60.
__________________
Jerry
"dorf_online"
  #12
Old August 11th, 2009, 10:24 AM
mvn's Avatar
mvn mvn is offline
Well, the SX tabs do work and mount very nicely to the 192 hull. The stainless tabs mounted further from the centerline will definitely work. The SX tabs, even though they are mounted close to the centerline offer tremendous lateral stability. Either model will work.
Mark
__________________
  #13
Old August 13th, 2009, 05:04 PM
The Picture that they sent on recommended install goes against the install instructions. I will be going out Aug 21 to test again. I have to make adjustments. I will take pictures on my install but I put in same place as picture above. So Far has made choppy water nice. Dont know about top speed yet, Plain is alot better.
  #14
Old August 14th, 2009, 10:17 AM
mvn's Avatar
mvn mvn is offline
That's great! If you find your top end has suffered, back off on the pressure a bit. You will find the setting that works best for you by trial and error.
Mark
__________________
  #15
Old August 25th, 2009, 11:18 AM
Well I tested them after adjustment. The tab on drivers side came off banging on boat. Removed tab from acuator. After getting boat out of water found that lock pins for tab were still there. lock pins put in facing one other. Should not have happened but it did. With boat at full weight capicity boat still list bad. With boat having 800lbs it does great. Tabs work great on the plane end. The 192captiva is rated wrong on the weight.
The fix I suggested to my wife is to buy a bigger boat. I think a 27 foot will do. :-)
  #16
Old August 26th, 2009, 04:04 PM
I might try the ones the Dorf is showing, But what about those new holes in the back of my boat?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help winterizing 89 186 captiva indiana324 Rinker Boats 1 September 9th, 2008 03:28 PM
94' Rinker Captiva 195 w/4.3 quadridermx Prop Questions and Topics 4 July 2nd, 2008 04:07 PM
Rinker with a list (leans to the left) Mod49T Rinker Boats 7 September 20th, 2007 10:08 PM
Left Blinker on Trailer works when Right or Left on Truck is on! Scuda11 Trailers and Towing 20 September 20th, 2007 09:02 AM
Boat leans (list) to left when on plane dpbj6 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 1st, 2005 02:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
