  #1
Old July 8th, 2009, 11:49 AM
Oskar Oskar is offline
Default Oil mix ratio for 4 hp Evinrude????
Hello again,
Some may recall my recent post regarding the purchase of a 4hp evinrude (E4REIA - 1991), which has seen VERY little use. In fact, it has not been used since 1993 and looks like it. As such, I've ordered a water pump kit, all O-rings, prop seals etc. in the bottom end.
I'd like to confirm the oil mix ratio for this motor. I do not have an owners manual, and have seen the general rule of 1:50 from the evinrude website. Is this applicable to this motor? Also, due to the low use of the motor, I will follow break in procedure and double the oil for 10 hours.
Thanks again for your help,
Dave
  #2
Old July 8th, 2009, 02:15 PM
Rick. Rick. is offline
Default Re: Oil mix ratio for 4 hp Evinrude????
Hold up there!! First congratulations on the motor, I'll bet it's sweet. I wish I could find an equal. Very little use. 50/1 TCW3 is the right mix. I didn't see ( don't remember) your prior post but you shouldn't be changing prop seals unless they are proven leekers. Just makes no sense to me. You don't need to double the oil mix but you do need to spray some oil into the cylinders prior to pulling the rope due to the fact they are likely very dry after sitting all that time. You won't be sorry to get a manual and you will be sorry if you don't. I get them from eBay. Don't get the cd manuals make sure they are original OMC service manuals. There is at the top of this forum a TOP Secret File that will tell you what you should be doing to a motor that has been inactive. Here is a link to the parts break down for it. Enjoy, and best of luck. Rick.
http://shop.evinrude.com/
Edit: just noticed the link to you p-post. That is a great looking motor for sure. Your a lucky man to have it.
  #3
Old July 8th, 2009, 11:38 PM
Thanks fo the good advice Rick. I will save the prop seals for a rainy day and just replace the water pump and O-rings. I'll also head your words and spray/inject a bit of oil in the cylinders before starting. I'm in the process of finding shop manuals for both my motors.
I agree that I found a great little back-up motor and can't wait to give it a whirl.
Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'78 35 HP Evinrude Ratio Fullspectrum Johnson & Evinrude Outboards 2 March 31st, 2008 07:05 PM
Oil/Gas Ratio for Evinrude 28 HP dpbarr Johnson & Evinrude Outboards 1 August 5th, 2004 05:28 PM
gas&oil ratio 67 evinrude WannaFish Johnson & Evinrude Outboards 1 August 19th, 2003 06:30 AM
Evinrude 115- yr?/oil-gas ratio/HP? mosh Johnson & Evinrude Outboards 2 June 22nd, 2003 02:58 PM
89 evinrude 8hp gas oil ratio evinrude dude Johnson & Evinrude Outboards 1 March 26th, 2003 06:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
