Re: Rear drain plug
start at the bow or ski locker, and use a coat hanger and the hose. try a combination of the two, until water flows into the engine compartment or the back of the boat freely. I have had to do this to mine a couple of times because of pine needles n stuff getting down in there. Put the hose nozzle directly over the hole and blast the water thru until it is flowing freely, use the coat hanger, repeat. I got all kinds of crap out of mine that way. then work it all out the drain plug hole with the hanger at the end.
