Re: 1984 mercury outboard 7.5hp not pumping water
Here is a thought for you to try assuming water pump is pumping & water passages are clean. The intake on these motors is through a little screen on the underside of the anticavitation plate right above the prop. If your idle relief holes which are right below the lower cowling in the rear are plugged up with oil/exhaust goop, then when you are idling, all of the exhaust goes through the prop hub and bubbles up into the water intake. This is particularly noticeable when you crank it in a barrel. If you take it out and run it in forward in a lake, then the exhaust is blown back and the water picks up and flows fine. If this is the case, then you need to pull the powerhead and clean out the idle relief holes. Or you might can get the holes cleaned by using some solvent and rodding it out and not have to pull the powerhead. Good luck and hope this might help.
