jtcarter
- Apr 26, 2008
- 226
1995 175 evinrude intruder. Alright get one thing kind of solved and now i have another issue. I'm not getting the rpm's i used to get. Motor was running about 5600 wot. Now if i trim it out to the max it might be getting 5100 to 5200. Lost about 7 or 8 mph also somewhere. Pulled the spark plugs and 1-5 all looked like they should, almost lean looking though, but they do have a light tan tint and they're not white crusted. Anway i pull number 6 and the diode is almost black, maybe one small section of diode that isn't black. Earlier in the year my gps read 64 at 5600, now 5100 or 5200 at 56 mph. Only plug with any noticeable difference from the other is number 6, but i can pull the plug in the drive and you can still tell a difference, though. Dang thing lean sneezed again today and the primer bulb was hard as a brick.
So in short the motor has lost some top end and rpm and number six plug is almost black on 75 percent of the diode. Coil breaking down at high speed? Is the plug baking? Causing it to turn black.? Is number 6 getting hotter than the others? Clogged or malfunctioning check valves? Primer bulb is staying hard and it still lean sneezed, Could it possibly be high speed orfice in number 6 clogged?
