jlinder
- Jul 5, 2004
- 1,086
Went to get the boat ready for the season. Started it up and ran it for about 5-10 min then it died and would not restart.
Removed the water/fuel separator and found it pretty empty and full of crud. Ordering another one but flushed it for now, refilled with gas and put back on. Engine ran for about 30sec-1 min then died again.
Removed separator and found it empty again.
Read the FAQ (thanks Don S) and have some good ideas for testing and will be going to pick up some of the gear but for now wanted to se if anyone had any ideas.
Specifics: 1988 OMC drive with 5.0L GM engine.
Thoughts:
1. Fuel pump and carb probably fine since the engine runs if it has gas.
2. Tank has gas in it (added some for good measure).
3. Suspect problem is between tank and separator/filter. Probably crud somewhere at the bottom of the tank or line. Is there a filter/screen in the tank?
4. Is there an easy way to drain/clean the tank? Since it is under the deck it would be a big deal to get it out.
Suggestions welcome
Thoughts:
Suggestions welcome
