-see second post regarding mouse damage-
I have 2002 115hp four stoke and it appears Cyl #2 is not getting gas. The boat will run at about 4000 rpm WOT. I replaced all the plugs and 1,3, and 4 look like they are burning fuel. Plug #2 is as clean as when I put it in, with the exception of some discoloration on the ground electrode. It does not smell like gas or burnt gas. I have the maintenance manual and I did the injector test - put a screwdriver on the body of the injector and listened for the clicking sound with the engine idling; it is there on all four injectors.
Any one know of any reasons why there would be no gas getting to the cylinder? Could the injector be plugged? If so, is there anything I could try
to clear it without taking the fuel rail out?
Thanks
Thanks
