  #1
Old July 7th, 2009, 03:01 PM
fisherman 690 fisherman 690 is offline
Default 75HP Mercury Dies with Strange Noise
I have a 1991 Mercury 75HP outboard - ser# 0C259832. I need help determining what is failing if you can help.
Motor starts and idles great. When throttling-up, engine runs great... then 5 or so minutes into run engine dies (a sound similar to the ratcheting sound the prop gears make if motor was left in gear while boat was still in motion - this noise starts to climb in volume at the motor looses power and dies). This sound is produced regardless of engine speed or boat speed, even at low revs. The motor will restart immediately. Once underway, the engine will die shortly thereafter - 3-5 minutes - it seems to be a heat build-up issue in the electronics.
Before the motor started to die (with noise), I was having problems with the motor seemingly loosing a cylinder (loss of power) - this was intermittant. After cleaning carbs, rebuilding fuel pump and adding water seperator unit the motor just dies now...
I have also checked the thermostat to make sure it wasn't stuck - I thought maybe it was getting hot causing detonation before the buzzer would go off.
The sound that I try to describe above was noted to be possibly an electrical arcing sound, but I have not yet removed the flywheel to see if there is any discoloration, blistering, carbon deposits, etc. I have fully inspected all high voltage spark plug wires and coils for tell-tail carbon marks, but have found nothing.
Compression is 110 across all cylinders, I have spark on all three cylinders.
I have swapped-out the switch box with a known good unit and the problem is still there - possibly the trigger or stator?
  #2
Old July 8th, 2009, 09:51 AM
Default Re: 75HP Mercury Dies with Strange Noise
bump...
  #3
Old July 8th, 2009, 10:09 AM
Just for conversation... Maybe the noise is from the gears... it only makes the sound as the engine just starts to loos power - I can almost hear the noise before the power starts to die-off. I'll take ohm reads on the stator, then heat the flywheel to see if I get resistance changes throught the stator.
Does anyone know of the proper ohm readings that I should get off the Mercury RED stator... my service book covers 9 & 16 amp stators with differnt stator part numbers listed (other than various look-ups on the web, I can't verify if I have a 9 or 16 amp stator). My current stator 398-832075A3 is listed as a 16 amp unit.
Dan
  #4
Old July 30th, 2009, 10:19 PM
Rossi The Heeler Rossi The Heeler is offline
Dan-
I've got a red stator with problems similar to yours...
My stator has grn/wht, wht/grn, a blue (appears to be to the coils), two yellows and there may be another... Too lazy to go look right now, but i'll tell you if you've got between 600 and 700 ohms on the grn/wht and wht/grn that the stator "checks" good. Mine checks good but still kills at anything around 3/4 throttle. If you have a blue wire, I'd check that from there (Stator-side) to ground. CDI says it should be open "OL" but I actually read some resistance... I'm leaning toward this not being good. I haven't figured my deal out yet, but figured I'd share my issues and findings, maybe it'll help my karma...
  #5
Old August 14th, 2009, 12:44 AM
darpalal darpalal is offline
If you haven't already resovled your problem, I can say I had a similar problem this year and it turned out to be that i had a crack in my oil line coming of the fuel pump. Once fixed the problem stopped.
Hope this helps you out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Strange Noise: need to fix sebas54 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 May 8th, 2008 07:39 PM
Strange Noise Knot@Home Johnson & Evinrude Outboards 7 June 1st, 2005 06:25 AM
2000' 75hp mercury dies at half to full thottle vol fan Mercury & Mariner Outboards 0 June 24th, 2003 08:11 PM
strange noise handball Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 26th, 2003 06:22 PM
'90 OMC 4.3L - Strange Noise frankmar Non-Repair Outboard Discussions 4 August 20th, 2001 05:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
