  #1
Old July 7th, 2009, 01:08 PM
bigp1612 bigp1612 is offline
Default 1992 evinrude 9.9 running rough/power loss
The evinrude was running pretty rough so I replaced the spark plugs and threw some sea foam in the gas tank. Seemed to work and was working great before it started even worse. Had it out on the water as a kicker engine was purring but then it coughed and stayed that way. It will start but tough to keep it from cutting out when idling. It will rev up in gear but its not smooth and not as much power as previously. If i don't push the choke all the way it will run in idle but its real jerky. If I push the choke in all the way it dies. I replaced the plugs again, but doesn't really help much. The plugs picked up a lot of soot/black even when just running for a few minutes. I'm not a small outboard expert by any means. Any suggestions would be appreciated. Thanks
Paul Clark
  #2
Old July 7th, 2009, 06:46 PM
Rick. Rick. is offline
Default Re: 1992 evinrude 9.9 running rough/power loss
Not sure about the condition of your gas but if it is fresh then it sounds as though it is time for a thorough carb. cleaning and a new carb. kit. That should make her run well again. I would also suggest you give it a seafoam treatment to burn away the carbon build up. Have a look at the top of this forum in the Top Secret File for directions for both procedures. Best of luck. Rick.
  #3
Old July 7th, 2009, 10:11 PM
petryshyn petryshyn is offline
Unfortunately, many things can give the same symtoms.
Start with checking the simplest first:
Check for spark at both plugs
Check compression if you have access to a tester
Then as Rick says, clean the carb if the above checks OK
__________________
Alias "schematic"
  #4
Old July 8th, 2009, 12:36 AM
Lion hunter's Avatar
Lion hunter Lion hunter is offline
Master Chief Petty Officer
Not that this is the problem with your motor but I have seen alot of kickers that get carboned up. Seems like alot of people run them at slow speeds all the time and never run them at WOT.
  #5
Old July 8th, 2009, 02:27 PM
Yes, I'll bet it's carboned up pretty bad. As a matter of habit I always run my motor at wide open at the end of a troll. I just think it makes good sense to heat it up and pour some gas through it and clean the plugs/exhaust a little before shutting it down. Rick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 15 Evinrude loss of power, rough idle jlsjoe Johnson & Evinrude Outboards 44 July 9th, 2009 04:47 PM
1992 Mariner 25 running rough kbe119 Mercury & Mariner Outboards 2 February 8th, 2009 06:36 PM
Loss of Power/Running Rough tdmontg Mercury & Mariner Outboards 0 July 5th, 2008 08:53 PM
Evinrude 40HP loss of power after 30 mins. running monoshock Johnson & Evinrude Outboards 24 July 2nd, 2005 08:11 PM
1992 200 HP EVINRUDE POWER LOSS RSTOLER Johnson & Evinrude Outboards 0 September 20th, 2003 06:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
