My new engine is no where near as fast as the old one, the old Mercury 2 stroke pushed my fishing boat along at 18 knots, the max I now get out of my new engine is 13 knots, but the engine only revs to 3500, which is 2000 or so less than it should do. The prop is a 10p, I have checked the transom height AV plate is level with bottom of boat and leg is aligned at 90 degrees to the water line, as per manufacturers specification. I have also checked the throttle to ensure correct range of movement.
Your help would be greatly appreciated.
