Re: 1957 18 horse gearcase seals
F_R thanks but I screwed up by posting 10 h.p , meant 18 h.p. I must be getting old. thinking one thing and posting something else. reworded origional
post and title. now lets see how it goes.
OK, here's the skinny on the matter: Sierra does not have the prop shaft seal for the '57 and older 15/18hp motors, therefor they do not have a seal kit for them either. Their 18-2684 has all the other seals, but includes the wrong prop shaft seal. Here are the part numbers for your '57:
Drive shaft seal- 321788, Sierra 18-2032
Shift rod seal- 301877, 18-7100
Fill plugs washers- 307552, 18-2945
Drive shaft o-ring- 303067, 18-7116
Spegetti seal- 309044 (50 ft roll) 18-2534
Prop shaft seal- 302495, No Sierra
Bearing head o-ring- 302493, 18-7112
The 302495 prop shaft seal is $35. Another way around the problem is to order the 18-2684 seal kit (1958-73) and get somebody to make a reducing sleeve to adapt the newer seal from the kit to your gearcase head. I have done a few.
