  #1
Old July 6th, 2009, 10:04 PM
Howard the Mason Howard the Mason is offline
Default 22' Pontoon- I need advice very slow
I have recently purchased a 1995 Crest 22' Pontoon with 26" pontoons and a 60hp Johnson Motor. With me and my wife and my 4 little children the boat runs between 13-14mph with a WOT of 4300rpm. My prop pitch is 13&3/4" x 13" and is the original prop. I know its not a speed boat but I want to increase the speed because we have very big lakes around here and takes long time to get across with such a slow speed. Do you think this is a normal speed for this size boat and motor? Or the right size prop? If not, do you have any suggestions for me to help increase the speed. I would like to run between 22 and 25mph. I have a 1985 115hp Johnson I was thinking of putting on the boat, but the boat is only rated for a 90hp.
  #2
Old July 6th, 2009, 11:01 PM
Silvertip Silvertip is offline
Default Re: 22' Pontoon- I need advice very slow
If you are using the boat speedometer for your observations that's not a very good measure. A gps would give you much more accurate readings. However, you are correct, a 60 HP engine should push that boat at least in the 18 - 20 MPH range. So step one is to ensure the engine is properly tuned and actually making full power. Make sure the throttle is opening fully (carb butterflies perfectly horizontal in the carb throat). If you have a tach, the engine should be running in the 5500 RPM range. If wide open throttle is less than that you may have a prop with too much pitch. Are you sure one or both pontoons are free of water.
  #3
Old July 6th, 2009, 11:18 PM
hvachillbilly hvachillbilly is offline
Quote:
i have a 21ft suntracker with a 60 hp motor can you recomend the proper prop my engine is a four stroke big foot and wot will over rev engine thank god for the tach i guess my oem prop is a 3 blade 14 x 10
__________________
give a man a fish he eats for a day teach a man to fish and he is frustrated for a liftime :hillbilly
  #4
Old July 7th, 2009, 03:27 PM
how do i know if there's water in my toons and why would my 60 hp be running wide open at 4300 rpms
  #5
Old July 7th, 2009, 05:22 PM
chrisg chrisg is offline
Quote:
With the toon on the trailer, have someone stand beside it while you rock it back and forth,if you hear sloshing, you have water in them. The next question will be how to get the water out - there are postings on that.
__________________
Chris
Gave up on searching for a lake in Iowa!
  #6
Old July 7th, 2009, 09:26 PM
My gosh people are hijacking threads latelky. HVACHILLBILLY, you should post your question in a separate thread. Jumping on someone elses makes it hard to keep track of who is who. Your prop should be a four blade pontoon prop from Mercury in a 14 x 11 pitch.
HOWARD: since your engine is running at 4300 rpm wide open it may be because 1) it is not running right, 2) the prop has too much pitch, 3) there is water in the tubes, 4) you have a very heavy pontoon 5) the throttle isn't opening fully 6) the tach is incorrect and those are just a few things to start with.
  #7
Old July 7th, 2009, 10:02 PM
sorry new to forums did not know proper etiquette and thanks for info just the same
__________________
  #8
Old July 10th, 2009, 07:33 AM
I checked for water in the toons and there was none. Still can't figure out why my wot is only 4300 butterflys are all the way open. Also i have a 115 2 stroke johnson i was considering putting on the boat but it's only rated for a 90 how big of a problem would that be or you think it would be fine.
  #9
Old July 10th, 2009, 08:45 AM
lowell7963 lowell7963 is offline
Send a message via Yahoo to lowell7963
It would be a bad idea, and illegal to put a motor on that is larger than what the boat is rated for. Figure out what is wrong with the motor you have first. It may not be that much wrong. 4300 rpm is low.
  #10
Old July 10th, 2009, 08:14 PM
what size prop do you think would fit on my boat now i got a 13 3/4 x 13
  #11
Old July 11th, 2009, 02:16 AM
mrdude mrdude is offline
assuming the motor is running well and yor not pulling around extra weight that was talked about.. i would check around and find a prop shop or someone that would have used props in your area and explain the problem .. maybe they would be nice enough to let u try a lower pitch prop before you potentially buy one. one more thing.. not sure if it was mentioned but are you sure your tach & speedo are accurate? something to check out to eliminate those possibilities.. especially the tach!
  #12
Old July 11th, 2009, 12:02 PM
joecooool joecooool is offline
Your problem is your engine isn't running at its rated hp. In order to get 60 hp, you are going to have to find out why its not going past 4300 rpms.
My guess would be either the throttle cable or the previous owner installed a governor. If that boat was ever a rental, I can assure you it has a governor.
  #13
Old July 11th, 2009, 02:27 PM
Hey i want to thank every body for there advice i really appreciate it i just took my boat out by myself it has a 60 hp i took my gps to check the speed it was 14 mph and the with wot it got to about 4800 if i trimmed it up even though the boat is 22' with 26" toons it should do better then that shouldn't it
  #14
Old July 11th, 2009, 04:54 PM
steelespike steelespike is offline
Yes I would think 20 mph is possible. I checked a couple of 20 and one 23 with 50 and 60 hp; speeds ranged from 19.5 to 21.4. 2 with 13" props at about 5,500 one with a 14 X 11 at about 5,500.
Weight distributon is important and carefully trim motor for the best
performance.
You might confirm running on all cylinders.Do a compression check.
raise the motor one hole.Won't help much but could add a little.
You could try a 11"pitch pontoon specific prop usually 4 blades.
A 2" pitch change is only going to add about 400 rpm.
with luck it will put you at 5200 but I feel still low.
Are the tubes clean?
  #15
Old July 11th, 2009, 09:58 PM
the tubes a very clean besides on of the tubes is missing the inner fin also will check the compression tomorow any ideas what it should be i know they should be all within 3-5 lbs of each other
  #16
Old July 14th, 2009, 02:34 PM
I have a 24 foot with dirty logs, and a 60hp Merc BF, I just measured its speed with a GPS, and I get 19MPH. thats at 5400 RPM, WOT gives me 5800 RPM with no increase in speed ( only engine sound).
__________________
Chris
  #17
Old July 15th, 2009, 12:17 PM
Manufacturers are secretive about their compression figures.
Rule of thumb 100 psi is the ideal minimum within 10% between cylinders.
Have you checked that throttle opens all the way?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need advice on buying first Pontoon gpugh0501 Pontoons 4 May 2nd, 2009 08:14 PM
pontoon building advice fspitzer Pontoons 11 August 22nd, 2008 01:11 PM
New pontoon ...need advice wi-rob Pontoons 8 August 10th, 2008 09:58 PM
Need Pontoon Advice!! chainboater Boat Topics and Questions (not engine topics) 3 July 29th, 2007 08:08 AM
Pontoon boats. Looking for a little advice kozanecki01 Boat Topics and Questions (not engine topics) 25 December 20th, 2004 03:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
