Expidia
- Aug 26, 2006
- 2,374
I don't understand why this is like this. What am I doing wrong.
I was trying to teach my daughter how to pull up her new to her 99 O/B.
I have a Merc 9.9 and the lock is nothing like this one.
I was showing her how to move the pin to another hole and the only way to get the motor to tilt up so I can change the pin hole is to shake the power head back and forth while you wiggle the pin out. Because the motor rests on the pin, I can't pull it out until I drop the motor down without the pin in it to release the latch that prevents the outboard not to pop up in reverse.
Once the pin is out the motor drops down towards the transom an inch or so and only then can I release the locking latch and then the motor can be pulled up to a full tilt position. Then I can move the pin to what ever hole I want and then lower the motor again. Once it locks into place the whole unlocking pin wiggling, head shaking procedure starts again.
This is down right dangerous since we can't just pull up on the lever which should allow the motor to tilt up. If we needed to pull the motor up quickly like if the bottom is coming up real fast.
The locking latch on the side is fully functional. But I've never experienced this with any other O/B. I know I must be missing something here. The shift was in neutral position and the motor was off of course each time I changed the motors position. If my Daughter tries reaching down and wiggling out the pin while shaking the power head she is sure to fall over board
Any help with this issue would be appreciated.
