Re: 40 HP Johnson oil alarm
which alarm is it?
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat and fuel restriction alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
has the motor been sitting a good while? did you try priming the oil system?
personally i would disable the oil side on the VRO2 and premix.
