tdcardwell
- Jun 12, 2009
- 1
I have a 150 HP 1995 Evininrude Intruder on my 17' hydrosport 185. I have owend the boat for over two years and never had any problems out of the motor....Until two weeks ago. I got on the lake early in the morning just like always, got the boat off the trailer and ran to the first fishing hole 2 miles up river. The motor ran fine just like always. I fished that hole for a little over an hour and headed for the next hole. As soon as I got on plane the motor lost power, it felt like I hit something, I stopped turned the motor off and raised it out of the water. Nothing.....So I put the motor back down fired it up again, sounded fine at idle, so put in gear and put the hot foot down to get out of the hole. About half way up to plane it does the same thing, so I try to just force it to run. I can't get RPMS above 2000 and it runs very rough. Giving up I head back to the ramp, just barley able to get the boat on plane, Along the way the motor had a few very short spurts of normal running but they never lasted more than a few seconds. Heat broken that baby has failed me I put it on the trailer and head home. Six or so hours later I get her back out to "just check things out" I run the boat for 15 min or so minutes with stopping and it runs just fine. I take it to the shop anyway just so they can check it out. the mechanic says he ran it hard for 30 mins with out stopping and it runs just fine.
So I pay them for their time and take my baby home, today I leave work early just to go fishing (and to test the boat for myself). I take her off the trailer fire it up and let it idle for 5 or so mins....no problems. I run about 3 miles up river as close to wide open as i can get this takes about 15 or 20 mins again no problem. I stop and fish for about an hour and head to the next hole again about 10 min of driving almost full throttle. Again, no problems....so I fish for about anther half hour or so,then I begin to head back to the ramp, a bout half way up to plane the motor does the same thing again except this time I cant get much above 1500 RPMS and if I let the motor idle it will run for a min or so them die, if I put it in gear and try to give it gas if I get past about 1/4 throttle it bogs down and dies. This time it will not get up to plane it will just barley go fater than idle speed and if i give to much gas it bogs down and dies.
I am not that experienced with fixing 2 stroke motors, and don't really do much work on the motor myself. Is there anything I can tell mechanics to check for?
Any suggestions or Ideas would be greatly appreciated!
Thanks
Thanks
