1971 650 65hp mercury wiring nightmare
Ok I got the boat and the motor was sitting out in someones front yard, I got new plugs, wires, cap, key, and got tested compression. Everything looks good but I got a problem. I cannot get the darn thing to fire over will turn but not fire. I checked the usual stuff and found that there is no power to the ignition switch box? So how do I test the coil to see if I can get fire there? And I have a book but WOW wiring on that perticular motor is a Yikes.. can't tell color codes on wires there faded bad.
Thanks
