Dana
ginangel
We own a 1984 50 horsepower mercury outboard. It has 2 Walbro carbs w/integral fuel pumps..It only seems to run off of one fuel pump once we are out in the water.The upper carb doesn't appear to be functioning at all. Upon inspection of the gaskets and diaphrams of the integral fuel pumps, we found wear of these flaps which cover the vacuum holes that appear to power the pumps. We checked these carbs through out and they appear to be very clean..Does anyone know if these flaps in the gaskets could be our problem??
CharlieB
Re: Dana
Yes, those little 'flap' are one-way valves, any failure and the fuel pulses back and forth, no flow into the carb.
Replace them with a new rebuild kit.
