  #1
Old July 6th, 2009, 10:38 AM
IndyRob IndyRob is offline
Default Patching Aluminum Holes
I've got a hole about the size of a #2 pencil in my aluminum boat that allows it to take on water at a pretty decent rate. My "fix" was to jam a plastic grub in the hole backed with an old rivet, but that is only a temporary solution.
I'd like to find a DIY solution for patching holes in aluminum that will last a good amount of time and not cost me a ton of money. My first thought was to try some soda cans and JB weld... but I know nothing about that stuff. My second thought was to use Bondo, but I just don't know.
  #2
Old July 6th, 2009, 05:47 PM
oops!'s Avatar
oops! oops! is offline
Default Re: Patching Aluminum Holes
there is some stuff called gluvit...
im not a tinny guy, but i would get some alum and weld it into place....i imagine rivits could be used.....but gluvit is a great product.
cheers
oops
__________________
IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
  #3
Old July 6th, 2009, 06:00 PM
MushCreek MushCreek is offline
We used to scuff up the aluminum real rough and put a fiberglass patch on it. It would probably work even better with today's epoxies. We actually patched the oil pan from a crane engine with fiberglass!
  #4
Old July 6th, 2009, 06:04 PM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
A #2 pencil size hole like a new pencil about 6 or 7 inches long !!!
Get a bolt that fits that hole, coat it with some 3m5200 and tighten it up.
For other holes or leaks we suggest that you re-buck the rivets and use gluvit on the rivets and seams. It is a penetrating epoxy designed for that.
For serious large holes get a piece of aluminum (fairly thick) something like a piece of an aluminum street sign (hint hint) coat it with gluvit and rivit it in place or use 3m5200.
Use only stainless steel bolts and aluminum rivets when working with an aluminum boat. Do not use regular steel or any pressure treated wood since they will react with the aluminum.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
patching holes in the console? airframer Boat Restoration and Building 2 June 1st, 2008 05:01 PM
Patching aluminum transom holes Always Broke Boat Restoration and Building 5 May 30th, 2008 02:10 AM
patching holes in aluminum boat scully222 Boat Restoration and Building 3 January 8th, 2008 03:16 AM
patching screw holes moeMC Boat Restoration and Building 6 September 28th, 2006 05:51 PM
patching underwater screw holes Twidget Boat Restoration and Building 4 February 3rd, 2005 09:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
