Re: AQ151 dwell angle
well, you could adjust the dwell to about 45 or 50 if it still runs, and readjust the timing. see if it runs better, if so recheck the dwell and continue adjusting toward 62 +/-. Reset your timing again and see where your at.
Are these new points? I adjusted the dwell on my boat last set of points and had similar findings, much smaller gap than i would have expected. I put new points in this spring, gapped them using a feeler gage and the dwell was close, only minor adjustment from that point.
remember, by adjusting the points you are adjusting the dwell. The dwell is the most accurate measure.
Good Luck.
