grandpacrotchrocket
- Jun 12, 2009
- 5
I think my problem is in the lower unit. Motor will not shift in reverse, but if I put a little pressure on the lever in the engine compartment it will go into reverse. Removed the cable from lever and I can not shift it into any gear. I can use a bad against the lever and force it into reverse. I'm thinking my problem might be with the shift lever in the lower unit. If so do I need any special tools to repair my problem? Or is this just change out the lower unit for $800. thanks
