  #1
Old July 5th, 2009, 11:12 PM
jlcross81 jlcross81 is offline
Default wiring diagram 1995 115 evinrude
Does anyone have a wiring diagram for this engine??? I am missing something up near the switch, and if I had a diagram to look at I could get it figured out. Thanks
  #2
Old July 5th, 2009, 11:20 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: wiring diagram 1995 115 evinrude
Don't have a diagram, but what is the problem you've encountered?
  #3
Old July 5th, 2009, 11:50 PM
It started the other day, but I removed the steering cable, and put a new one on. Now the engine won't turn over, but I can hear the choke kick in, and my gas, and alternator gauge still works. I think I may have lost the ground, but I am not sure. When I pulled the panel to look at all the wires, I noticed a couple that have what appears to have bare spots (mice holes) in them. I just don't want to get one backwards. Thanks
  #4
Old July 6th, 2009, 01:30 PM
Joe Reeves's Avatar
Hopefully someone gets that diagram to you. In the START position, voltage should flow between the "B" (battery) terminal of the ignition switch to the "S" (solenoid) terminal of the ignition switch, and from that "S" terminal to one of the small 3/8" nut terminals of the starter solenoid at the engine.
Unfortunately I don't know what color that wire might be on the 1995 model. The other 3/8" nut terminal of the solenoid simply connects to a powerhead ground.
A neutral safety switch exists within the normal type control box OR within the top console type control box that might have been knocked out of adjustment or had a wire pulled off when doing that steering cable job. This switch normally prevents voltage from reaching the starter solenoid when the engine is in gear.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wiring diagram 25 evinrude raffoboo Johnson & Evinrude Outboards 2 July 20th, 2009 09:48 PM
Need Wiring Diagram 1995 Hp jimg984 Mercury & Mariner Outboards 10 April 24th, 2009 04:21 PM
ISO wiring diagram for a 1995 40 HP Johnson Leggman Johnson & Evinrude Outboards 1 July 15th, 2008 11:11 AM
Evinrude 70 VRO wiring diagram DellQuayDory Johnson & Evinrude Outboards 1 April 27th, 2005 03:03 AM
85 hp Evinrude wiring diagram edki Johnson & Evinrude Outboards 1 April 10th, 2005 10:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
