  #1
Old July 5th, 2009, 10:26 PM
Rob33 Rob33 is offline
Default Mercury 150 hp making a loud clicking noise
Seems like a big problem. My mercury 150 outboard is making a loud clicking noise that happens at idle and goes quicker as I speed up. The engine is also overheating pretty bad. Any ideas? I changed the lower gear oil and it was clean and replaced the spark plugs. I'm looking for some places to start check for the problem. As always, thanks for the help.
Rob
  #2
Old July 6th, 2009, 02:22 AM
Default Re: Mercury 150 hp making a loud clicking noise
I also changed the thermostats and the engine still overheated.
Rob
  #3
Old July 6th, 2009, 02:43 AM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
It is hard to diagnose a clicking noise without actually hearing where it is coming from and what it exactly sounds like. If you are lucky, it is just a bad water pump and so I would suggest that you replace the water pump and see if that stops the clicking sound and the overheat condition. If it does not, then it may be the motor (failed bearing, knocking piston rod, broken piston ring, etc.) and I'll leave it to others with more experience in that area to suggest how to troubleshoot engine knocking sounds.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #4
Old July 6th, 2009, 01:30 PM
Are the water pump and the impeller one in the same? I am getting the same constant stream of water out the back of the engine. Also, after running at idle of just abouve for a while, the engine gets real rough.
  #5
Old July 6th, 2009, 02:14 PM
hkeiner's Avatar
Ensign
The impeller is part of the water pump assembly. It is made of rubber and may be replaced alone or the whole water pump assembly may be replaced. For all the effort involved in removing the lower unit and disassembling the water pump to get to the impeller, some just go ahead and replace the whole water pump assembly if there is any doubt as to excessive wear on any assembly parts. This costs a bit more in parts, but the potential cost of a blown motor (due to failed water pump) makes the added cost of replacing the whole assembly seem minor. Just my thoughts...
__________________
  #6
Old July 6th, 2009, 08:50 PM
Couple more things about the problem:
It gets hot at high rpm but stays very cool at idle
The noise sounds to be coming from the engine head and not the lower unit
and mabye knocking is a better term then clicking.
I'm worried it sounds like a piston issue, but not sure if that would cause higher temps?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Making loud noise when turning HELP!!! 2004SSI180 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 April 27th, 2009 11:13 AM
1988 force 50 making loud noise cron416 Force & Chrysler Outboards 4 August 10th, 2008 11:00 PM
steering was stuck now making clicking noise KLKM Boat Topics and Questions (not engine topics) 4 December 29th, 2006 09:23 AM
Manifold steam and loud clicking noise 2000 Elisa's Ring SR 24 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 October 20th, 2005 11:55 AM
Starter making loud noise and sounds like it is spinning lee74carlson Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 26th, 2003 12:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
