Can anyone advise a safe way to test fuel pump? I've done a lot of work on this engine (VP AQ131D) over the last month and am now trying to crank for the first time. It turns over when using starting fluid but won't start. Have checked fuel line and filter and no obstruction. No squirt of gas from the carb jet when I operate the accelerator pump. After cranking for a few minutes, I have no fuel in filter and only a couple of drops in the line from tank to filter. I don't believe there is an anti-siphon valve on the tank - would it be in the tank or right where the fuel line attaches?
This pump worked fine last October but it was off the engine for a couple of months. Should I just replace or is there something else to check first??
