the problem is there is no way to block the boat on any of the outside edges where it's strongest and double riveted. it's a roller trailer with side rails, when i block corners the lights are in the way to pull out trailer, light bracket is welded so can't remove, move in a foot on transom, i can get in but block needs to be narrow to allow roller to sqeeze by, by narrow i mean less than width of cinder block becus thats what i'm using as base. plus, when i lower trailer on tounge to get height, then jack up to block the trailer always moves a bit and disturbes block becus it's so narrow.
i can get to a spot but it's not on a edge, it's right in middle of boat on outside of chine, a foot in from transom....if i use about a 12x12 sq piece of something, is there any chance of popping thru the hull??...the boat has no weight in it and only has notor on it, 60hp and boat is 17ft cc alum.
really can't be popping thru hull......i do have 2 ski hooks on stern, could rig something to suspend from rafters if sure hooks will hold.
all ideas appreciated.
