  #1
Old July 5th, 2009, 01:20 PM
fox.noah fox.noah is offline
Default 1958 Evinrude Fisherman 5.5hp pops out of forward
Hello,
I have just recently started having this problem with my outboard. It continuously pops out of forward gear. I have never taken it apart, and to my knowledge it has not been damaged when this problem started. It is a manual shift with a lever in the side of the motor. Any help would be greatly appreciated, but nothing too technical, I'm kinda knew to outboards.
  #2
Old July 5th, 2009, 01:33 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: 1958 Evinrude Fisherman 5.5hp pops out of forward
Hi noah....popping outta' gear usually means that the clutch dogs "ears" have worn over and possibly the same with the gears. Over time, the well defined edges of the "ears" wear over from engaging each other when shifting. This causes the ears to disengage and the engine to come out of gear and possibly going back into gear. This has the effect of feeling like your hitting a log in the water.
Remedy is to replace the clutch dog and if warrented, the forward gear also as this gets more ware than the reverse gear. I have seen some guys take the parts to machinist and have them remachined. But they do have to be perfect and not a lot of material removed.
Hope this helps.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old July 5th, 2009, 02:05 PM
F_R F_R is offline
Hope this helps.
No arguement with the above statement, but just to clear up some possible confusion--the detent spring is in the lower unit on a 5.5. Because of that, the "log jump" sensation may be missing and it will simply kick to neutral and stay there. Here is a totally worn out clutch dog. They will kick out way, way, way before getting this bad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
shifter stuck in forward 1967 6hp evinrude fisherman smartboy1 Johnson & Evinrude Outboards 5 July 23rd, 2009 03:53 PM
6HP Evinrude Fisherman no forward? Ron43 Johnson & Evinrude Outboards 5 July 28th, 2008 03:03 PM
'65 evinrude 28h. pops out of forward gear myles27 Johnson & Evinrude Outboards 3 June 16th, 2007 03:14 PM
1974 25hp Evinrude Pops out of forward gear 603tehe Johnson & Evinrude Outboards 4 September 13th, 2004 01:20 PM
1972 Evinrude Pops in and out of forward Donnis Reese Johnson & Evinrude Outboards 2 June 21st, 2002 04:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
