  #1
Old July 5th, 2009, 10:02 AM
Costly Affair Costly Affair is offline
Send a message via AIM to Costly Affair Send a message via Yahoo to Costly Affair
Default Toon Cavitation Problem
I have a 20' toon with a 50 hp 2 stroke Johnson, circa 1998 on both. I have been having cavitation problems for quite some time. Finally changed my prop to 13 X 11. Took the boat out to test it and ran perfect for about an hour. Was ready to kiss a pig I was so happy. Then, it started cavitating again. I am at a loss. Why would it run perfect for an hour, then not? Anybody have a suggestion? Motor is down all the way.
  #2
Old July 5th, 2009, 10:42 AM
EGlideRider EGlideRider is offline
Default Re: Toon Cavitation Problem
It would seem to me that if it ran good for an hour, it should run good all day unless other parameters changed.
My best guess is that perhaps some weight was shifted forward such as a passenger moving up front.
I don't think that an hours fuel usage would have shifted the weight much.
If you really have a cavitation problem, then you must continue to experiment with prop sizes and weight distribution. If you have a ventilation problem then you must lower the motor more or shift more weight to the stern.
  #3
Old July 5th, 2009, 10:21 PM
Jeep Man Jeep Man is offline
I subscribe to the notion of "There are no stupid questions, just stupid answers." So I will ask the question, is the motor a long shaft version?
__________________
I've fished for half of my life, the rest I just wasted.
  #4
Old July 5th, 2009, 10:42 PM
Good point Jeep Man.
  #5
Old July 6th, 2009, 09:42 AM
It has a short shank. Have tried many things, weight in back, front under over. Ran with bimini up and down. Tried tilting motor to different angles. I do not think that the small use of gas during that hour would have anything to do with it but maybe. Going to take it out again this morning.
  #6
Old July 6th, 2009, 11:42 PM
In almost all cases, pontoon boats need a long shaft motor. I had a short shaft on my old boat, and the only way it wouldn't cavitate was to have it tilted all the way down, virtually under the boat, resulting in poor speed and poor performance. Unfortunately, my only suggestions are to have your bottom end replaced with a long shaft if possible, or sell the motor and but a long shaft version.
__________________
  #7
Old July 7th, 2009, 06:14 PM
mayorjones mayorjones is offline
Angry Re: Toon Cavitation Problem
I have the same problem - have a 2008 21' Sun Tracker and am so frustrated with it I am very tempted to sell it. Love the boat, but can't stand going 8 mph.
I have ordered a different prop and am going to try that. I have a 50 hp 2 stroke, and understand that a bigger motor would help (longer bottom, bigger prop), but I hate to spend more than the $15k I just did to buy the thing.
We are to the point that I refuse to take friends out w/us because of making everybody sit in the back or go 5 mph, but being able to take friends out was the main reason we bought the thing.
Grrrrrr'!!!
  #8
Old July 7th, 2009, 06:53 PM
My new one is a 20' Sun Tracker with a 60 Bigfoot. I don't understand how or why a dealer would sell a boat with a motor not suited for the boat.
__________________
  #9
Old July 8th, 2009, 01:08 PM
WindyCityPilot WindyCityPilot is offline
Have a 20' Starcraft with a 40 Merc. Having similar issues as others. I believe my problem is ventilation not cavitation. The engine is not mounted all the way down on the transom....one more hole is available to lower it down. Hopefully this weekend I will pull it out and lower the engine down and see if that solves my problem.
  #10
Old July 8th, 2009, 02:19 PM
Mine does it no matter what - the motor is as low as it can go, and when trimmed all the way down, unless I've got 70% of the weight in the back of the boat, it does it. Not sure if it is cavitation or ventilation but can tell you it is frustration. And to add insult to injury, the guy at the local prop shop suggested drilling holes in it, which I then paid him to do, which only made the problem worse. So much for "expert advice"...
So, a new prop came today and we'll see how that works. My old prop was a three blade with no cupping. The new one is four blades with cupping - can't be any worse than it was, can it?
  #11
Old July 11th, 2009, 12:22 PM
I really do thank you people for your replies to my toon problem. The mystifying part is that it ran beautiful for an hour before the cavitation problem started up again after I replaced the prop with a 13/11. I just took it out again and it started cavitating right away. Had to run at low throttle for it to get anywhere. If it had not run for an hour like it should, I would then take some of these suggestions. I put gas in it and shifted weight to rear and that did not help. I know that it is very frustrating to you as it is for me but I still have the problem and really not solution other that get a long shaft. This is a Godfrey Party Kraft set up as fishing boat from the factory, 1998 vintage and the motor came with it and is a 1998 johnson 50hp 2 stroke. I am still looking for a solution.
Last edited by Costly Affair : July 11th, 2009 at 12:24 PM. Reason: Adding information
  #12
Old July 12th, 2009, 10:47 PM
Quote:
Because long shaft motors are not used on as many boats as a short shaft, often someone who has one for sale is more than willing to trade for a short shaft. Another possibility is to convert it from short to long by changing out the bottom end. Keep an eye for one with low compression or a blown head, selling for cheap. This way you keep the motor you know.
__________________
  #13
Old July 12th, 2009, 11:35 PM
dcherry dcherry is offline
I run into the same problem when the lake is rough. I have a 87 evinrude 50 hp and it is a short shaft. How far should the prop be in the water?
  #14
Old July 13th, 2009, 12:59 PM
lowell7963 lowell7963 is offline
Send a message via Yahoo to lowell7963
I'm curious is you are in a lake or river, and if running upstream or downstream makes a difference?
  #15
Old July 13th, 2009, 04:17 PM
I have the same problem - I am on a river, and it does it much more so going upstream. Is this a sign/symptom of something?
  #16
Old July 14th, 2009, 08:58 AM
Yesterday we lowered the motor one notch down. We took the boat out and again, it ran ok for a half an hour, then started the cavitating again. While out there, we re-distributed weight all around the boat and it made no difference. I am using the boat in Sarasota Bay, relatively smooth salt water.
I have now sent an email off to Godfrey Marine to see if they have any answers. Very, very frustrating. And again, thanks for the comments.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cavitation problem Stoehrdp Prop Questions and Topics 3 August 29th, 2008 04:41 PM
cavitation problem cjlake Boat Topics and Questions (not engine topics) 1 June 23rd, 2008 06:51 PM
cavitation problem georgiaboy Prop Questions and Topics 2 May 3rd, 2007 10:56 PM
cavitation problem backhoebob Prop Questions and Topics 10 March 24th, 2006 01:49 PM
prop/cavitation problem fowl intent Mercury & Mariner Outboards 7 April 30th, 2003 09:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
