TN_OnlyTime
- Jun 10, 2009
- 3
2003 Mercruiser 5.0 just revs but doesn't move above low throttle
Has anyone experienced this before? or have an idea as to the fix?
I have a 2003 Chapparal SSi220 with a Mercruiser 5.0. We were cruising at about 3500 rpms and the boat stalled. It started right back up but would not "go". I ruled out the throttle kill switch/cord and I did not hit anything. When I open the throttle more than ~10% the engine just revs without moving the boat.
The idle is normal, low throttle described above functions normal, reverse functions normal, and the boat has not stalled after the initial time. I made it back to dock and once out of the water I inspected the drive. Did not notice any damage or debris on the drive, prop, etc.
Any ideas would be great. Thank you in advance.
