i have removed the cap and cotter pin, and wanted to change the prop with a newer prop and i can not get the pin out it moves alittle one way and almost none the other, I did tap it with a hammer and a punch but not really hard, so before i took a hammer and started beating the pin out i did not want to damage lower unit case, shaft and or bearing and seals any suggestions....
