  #1
Old July 3rd, 2009, 11:52 PM
cappinbob cappinbob is offline
Default any carb people out there
i had the carb off my 3.0 omc,didn't remove it completely only unbolted it and layed it over on its side out of the way of replacing the intake manifold.now when i start it, it is running around 1500 rpm's and the idle screw isn't touching the base,checked for leaks, didn't appear to have any,using wd40
any ideas ?
its a holly 2 barrel,1990 OMC
  #2
Old July 14th, 2009, 03:59 PM
shopguy shopguy is offline
Default Re: any carb people out there
If you haven't found the problem yet. Very closely inspect the choke linkage all the way from the blade to the throttle shaft. It sounds like the fast idle cam is stuck in the high idle position. let me know howit goes
  #3
Old August 7th, 2009, 10:42 PM
ended up the screws on the butterflys were loose not letting them close to idle.
  #4
Old August 7th, 2009, 10:50 PM
bifflefan's Avatar
bifflefan bifflefan is offline
its always a good idea to remove the parts on top of the part your fixing so you can clean and inspect them at that time. thus saving this situation.
also using WD-40 to find a vacum leak, not so good. use starting fluid is better for the leak as when it takes a good sniff the RPM's will jump up thus revealing the leak area. Just be carfull what you spray it at and let the fumes dissapate.
__________________
1983 22' Starcraft SC221 Bowrider 470 Mercury
1974 16' Starcraft American Bowrider 85 HP Johnson
Once you eliminate the impossible, What ever is left,
No matter how unlikely, Must be the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Some people.... Gary H NC Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 April 25th, 2009 12:38 PM
2 people halls butt, 4or5 people not over 10mph lquested Force & Chrysler Outboards 9 June 9th, 2008 11:01 PM
For all the gun people Bob_VT Non-Boating Technical Topics 6 February 29th, 2008 12:38 AM
Q for all the MD people vegard Boat Topics and Questions (not engine topics) 5 October 9th, 2003 10:56 AM
6 people NOSLEEP Dockside Chat 7 November 20th, 2002 12:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
