90hp 1990/1989 Mariner 2srtoke 3cylinder outboard with electric start.
background:
I ran out of gas one day and hooked up the engine to a new tank. I know it takes a while for the flow, but kept trying to start the engine with no spark.
I then suddenly realized that the minus on the starter battery was really really hot as it had melted the end of my minus wire to the fishfinder.
The larger cable ends to the engine were fine, but a little warm.
I waited a few minutes and tried starting again, but this time absolutely nothing happened.
Troubleshot this:
Engine runs fine if using rip cord and key in run position.
Starter works, as I have tried to put a piece of metal between the 2 larger connectors on the starter solenoid and it starts the engine like before problems occured.
Now I am not sure if it is the solenoid or the actual key ignition which is the sinner? Although the connections do not look new, I do not think corrosion is the issue.
How do I find out if the Solenoid or key switch is faulty?
Is there a way to measure if the final turn with the key from run to start position is being registered?
Thanks
background:
Troubleshot this:
Thanks
