  #1
Old July 3rd, 2009, 07:12 PM
txboatman txboatman is offline
Cool '72 Evinrude 100HP Carb Cleaning for tomorrow
I have a 1972 Evinrude, and when I originally had it cleaned up and running last summer, I had the top speed up to about 35Mph, then slowly it has been getting worse and now to 20Mph. I cant even pull a tube anymore, so I figured I would clean the carbs today before a big day out tomorrow. Now I am unsure, what to do. Maybe, a bad float or gunk buildup in the carb? If I have to buy a float, where could I get one today? What do I cleanse the Carbs with and how? Any help would be appreciated. Thanks!
  #2
Old July 3rd, 2009, 07:21 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: '72 Evinrude 100HP Carb Cleaning for tomorrow
Ethanol and fuel lines
replace all fuel line with Alcohol resistant lines. Ethanol deteriorates, the rubber lines, then they start to sluff off on the inside, going directly to the carbs. Settling to the bottom of the bowl. Contaminating the carbs high speed jets. clean a rebuild carbs, flushing fuel line before connecting to carbs.
read the topics in the TOP SECRET FILE, 2nd thread in this forum.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 3rd, 2009, 07:27 PM
Does it sound like a carb problem? Since 10mph decrease over the last yr? How do I tell if the float is bad?
  #4
Old July 3rd, 2009, 07:32 PM
possibly, but i would check spark and compression first, using a $10 spark tester from auto parts store, set it as 1/2 inch gap, spark should jump that with a bright blue spark. using a screw in compression tester, you compression should be 100 psi or above, but the main thing is that the readings are with in 10 % of each other. this will tell you the health of you motor, before sinking parts into it.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old July 3rd, 2009, 07:49 PM
Boss Hawg's Avatar
Boss Hawg Boss Hawg is offline
Master Chief Petty Officer
Awwww- another last minute plea for help
"so I figured I would clean the carbs today before a big day out tomorrow"
Why not overhaul the carbs (cleaning dont usually cut it) say-- a week before the big outting You know your going to have to do it - Git-R-Dun
__________________
MY FISHIN BUDDY
East Texas Redneck
SEMPER FI
USMC '67 - '70
  #6
Old July 3rd, 2009, 08:28 PM
I went and got new plugs. The compression was within 7% last time it was tested a few months ago... I will check again. What should the plugs gap be set at?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
86 Evinrude 6HP - Removing carb for cleaning kcackler Johnson & Evinrude Outboards 13 June 10th, 2009 02:33 PM
1991 Evinrude 48 SPL, cleaning carb. noworries79 Johnson & Evinrude Outboards 3 September 18th, 2008 10:03 AM
Evinrude carb cleaning matrix29 Johnson & Evinrude Outboards 2 July 2nd, 2005 03:04 PM
83 evinrude 115hp carb cleaning help fsds123 Johnson & Evinrude Outboards 1 August 25th, 2003 09:03 AM
1966 100hp Evinrude, no fuel thru main jet of #4 carb nrawls Johnson & Evinrude Outboards 1 August 21st, 2002 11:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
