I took my boat out yesterday and the tach would only work up to about 2500 rpm. Above that it would go to 0 until you throttled back and then it would work again starting about 2500 rpm down to about 750 at idle. Any ideas if this is a bad tach or if the rectifier or timing base might be causing this? The motor is an 1975 Johnson 115. The motor starts easily and runs good. The tach issue just started and I don't want to start replacing parts or mess anything up until I know what is wrong. Any ideas?
