I have a 2001 jonhson ocean pro, when it sets mix oil leaks into gas line. why is this happening? Clean out out from line and cylinders and it runs fine once the oil is cleaned out
had that same problem, oil would actually fill my carbs.. oil tank was higher than the motor, and would siphon, into the motor. i ended up going premix, and disabling the oil side.
