  #1
Old July 2nd, 2009, 09:39 AM
samm835 samm835 is offline
Send a message via AIM to samm835
Default 92 Mariner-Starts, then won't start????
Ok I have a 92 115 HP Mariner, A couple of weeks ago I was in a cove fishing. Decided to come back to the docks and when I went to start it wouldn't do anything. I jumped started the motor at the starter soleniod, I was thinking it might have been the neutral safety switch because it did this once before.....but once I moved the throttle around the motor started. I replaced the neutral switch and still nothing. I tried to start again from starter solenoid and it would start just as easy as it always should....of course I don't want to start it that way more than I need to. Once I did start it that way, I shut it off and then tried to start it by the key and...NOTHING. I am so confused at what to look for to see what else could be the issue. Any help would be appreciated.
  #2
Old July 2nd, 2009, 09:47 AM
bustermin's Avatar
bustermin bustermin is offline
Default Re: 92 Mariner-Starts, then won't start????
there is a wire on your starter solenoid somtimes it is marked with an "S" have sombody turn the key to see if you are getting voltage to this wire on the solenoid when the key is turned. if yes then you have a bad solenoid. if no, check the fuse if its ok then trace the wire back to key switch and check for voltage at every break/connection between the solenoid and switch until you show voltage. when you find the place with voltage on one side and nothing on the other you have found the problem.
__________________
"A simple way to take measure of a country is to look at how many want in... And how many want out."
"Only two defining forces have ever offered to die for you: Jesus Christ and the American G.I."
England's Former Prime Minister Tony Blair'
  #3
Old July 2nd, 2009, 10:59 AM
Thanks, I will do the test tonight. If the soleniod was bad would you still be able to jump start from the soleniod?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
87 mariner starts every 5th try mudfish_2 Mercury & Mariner Outboards 1 April 7th, 2008 11:27 AM
Starts, dies, doesn't start, then starts Big One Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 3rd, 2007 06:44 PM
starts, won't start, starts, won't start. help speedy_100 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 August 2nd, 2006 11:11 PM
engine starts, won't start, starts again after trailering paulyboat Johnson & Evinrude Outboards 5 August 1st, 2005 09:35 AM
Almost starts: 1990 Mariner 90 Hp sgroer Mercury & Mariner Outboards 15 March 8th, 2002 06:38 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
