The boat is tiller steer and pull start / the motor will run with the throttle turned all the way but it isnt running as fast as it should is there anyway i can adjust that /sometimes it will bog down and sometimes stall when you give it throttle fast or slow more so if you turn it fast /and it also doesnt want to start unless it is wide open
