i just bought this boat,motor sunday. the motor did start but took some time. in the back yard it wanted to start with help of the starter but did stay running after 10 or so trys. it is a 1977 merc 850. he said he was using a 30:1 oil mix. what i have read it should be a 50:1 oil mix would to much oil make it hard to start ?. i think there is a few other issues why it's hard to start also. just haven't got to look at it yet. i have not done any work on it yet. pumping the primer bulb did not seem to help much. out sides of carbs were pretty dirty . might take a look at fuel pump. one other question this motor have a tilt switch on the motor some place if it does haven't found it LOL if not is it much of a deal to put one on the splash well. he also said he needed to let it idle for a 1/2 hour ???? after that it runs very well. that don't sound right.that don't sound right. there a thermostat in this motor? i will clean all the wire contact places. good idea to use electrical grease on connections ?
